#Region "Namespaces"
Imports System.Text
Imports System.Linq
Imports System.Xml
Imports System.Reflection
Imports System.ComponentModel
Imports System.Collections
Imports System.Collections.Generic
Imports System.Windows
Imports System.Windows.Forms
Imports System.Drawing
Imports System.IO
Imports MgdAcApplication = IntelliCAD.ApplicationServices.Application
Imports MgdAcDocument = IntelliCAD.ApplicationServices.Document
#End Region
Namespace AcadNetAddinCS
Public Class MoveRotationScaleJig
Inherits DrawJig
#Region "Fields"
Private mBase As Teigha.Geometry.Point3d
Private mEntities As New List(Of Entity)()
Private mTotalJigFactorCount As Integer = 3
Private mCurJigFactorIndex As Integer = 1
' Jig Factor Index
Public mLocation As Teigha.Geometry.Point3d
' Jig Factor #1
Public mAngle As [Double]
' Jig Factor #2
Public mScaleFactor As [Double]
' Jig Factor #3
#End Region
#Region "Constructors"
Public Sub New(basePt As Point3d)
mBase = basePt.TransformBy(UCS)
'TODO: Initialize jig factors and transform them if necessary.
mLocation = mBase
mAngle = 0
mScaleFactor = 1
#End Region
#Region "Properties"
Public Property Location() As Teigha.Geometry.Point3d
Get
Return mLocation
End Get
Set
mLocation = Value
End Set
End Property
Public Property Angle() As [Double]
Get
Return mAngle
End Get
Set
mAngle = Value
End Set
End Property
Public Property ScaleFactor() As [Double]
Get
Return mScaleFactor
End Get
Set
mScaleFactor = Value
End Set
End Property
Public Property Base() As Teigha.Geometry.Point3d
Get
Return mBase
End Get
Set
mBase = Value
End Set
End Property
Public Property TotalJigFactor As Integer
Get
Return mTotalJigFactorCount
End Get
Set(value As Integer)
mTotalJigFactorCount = value
End Set
End Property
Public ReadOnly Property AcEditor() As Editor
Get
Return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
End Get
End Property
Public ReadOnly Property UCS() As Matrix3d
Get
Return AcEditor.CurrentUserCoordinateSystem
End Get
End Property
Public ReadOnly Property Transformation() As Matrix3d
Get
'return Matrix3d.Identity; //* Change it to anything else meaningful.
Return Matrix3d.Scaling(mScaleFactor, mLocation).PostMultiplyBy(Matrix3d.Rotation(mAngle, Vector3d.ZAxis.TransformBy(UCS), mLocation)).PostMultiplyBy(Matrix3d.Displacement(mBase.GetVectorTo(mLocation)))
End Get
End Property
Public Property Entities() As List(Of Entity)
Get
Return mEntities
End Get
Set(value As List(Of Entity))
mEntities = value
End Set
End Property
#End Region
#Region "Methods"
Public Sub AddEntity(ent As Entity)
mEntities.Add(ent)
Public Sub TransformEntities()
Dim mat As Matrix3d = Transformation
For Each ent As Entity In mEntities
ent.TransformBy(mat)
Next
#End Region
#Region "Overrides"
Protected Overrides Function WorldDraw(draw As Teigha.GraphicsInterface.WorldDraw) As Boolean
Dim geo As WorldGeometry = draw.Geometry
If geo IsNot Nothing Then
geo.PushModelTransform(mat)
geo.Draw(ent)
Next
geo.PopModelTransform()
End If
Return True
End Function
Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
Try
Select Case mCurJigFactorIndex
Case 1
Dim prOptions1 As New JigPromptPointOptions(vbLf & "Move:")
' Set properties such as UseBasePoint and BasePoint of the prompt options object if necessary here.
prOptions1.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
Dim prResult1 As PromptPointResult = prompts.AcquirePoint(prOptions1)
If prResult1.Status = PromptStatus.Cancel OrElse prResult1.Status = PromptStatus.Error OrElse prResult1.Status = PromptStatus.Keyword Then
Return SamplerStatus.Cancel
End If
If prResult1.Value.Equals(mLocation) Then
'Use better comparison method if necessary.
Return SamplerStatus.NoChange
Else
mLocation = prResult1.Value
Return SamplerStatus.OK
End If
Case 2
Dim prOptions2 As New JigPromptAngleOptions(vbLf & "Rotate:")
prOptions2.UseBasePoint = True
prOptions2.BasePoint = mLocation
prOptions2.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
Dim prResult2 As PromptDoubleResult = prompts.AcquireAngle(prOptions2)
If prResult2.Status = PromptStatus.Cancel OrElse prResult2.Status = PromptStatus.Error OrElse prResult2.Status = PromptStatus.Keyword Then
End If
If prResult2.Value.Equals(mAngle) Then
Else
mAngle = prResult2.Value
End If
Case 3
'Dim prOptions3 As New JigPromptDistanceOptions(vbLf & "Scale:")
'prOptions3.UseBasePoint = True
'prOptions3.BasePoint = mLocation
'prOptions3.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
'Dim prResult3 As PromptDoubleResult = prompts.AcquireDistance(prOptions3)
'If prResult3.Status = PromptStatus.Cancel AndAlso prResult3.Status = PromptStatus.[Error] Then
' Return SamplerStatus.Cancel
'End If
'If prResult3.Value.Equals(mScaleFactor) Then
' 'Use better comparison method if necessary.
' Return SamplerStatus.NoChange
'Else
' mScaleFactor = prResult3.Value
' Return SamplerStatus.OK
'End If
Case Else
Exit Select
End Select
Catch ex As system.Exception
MsgBox(ex.Message, MsgBoxStyle.Critical, "Erro")
End Try
End Function
#End Region
#Region "Method to Call"
Public Function Jig() As Boolean
Try
Dim pr As PromptResult
Do
pr = AcEditor.Drag(Me)
' Keyword handling code
If pr.Status = PromptStatus.Keyword Then
Else
Me.mCurJigFactorIndex += 1
End If
Loop While (pr.Status <> PromptStatus.Cancel AndAlso pr.Status <> PromptStatus.Error AndAlso pr.Status <> PromptStatus.Keyword) AndAlso Me.mCurJigFactorIndex <= Me.mTotalJigFactorCount
If pr.Status = PromptStatus.Cancel Then
Return False
End If
If Me.mCurJigFactorIndex = Me.mTotalJigFactorCount + 1 Then
Return True
Else
Return False
End If
Catch ex As Teigha.Runtime.Exception
Return False
Catch EX As System.Exception
Return False
End Try
End Function
#End Region
#Region "Commands"
<CommandMethod("TestMoveRotationScaleJig")>
Public Shared Sub TestMoveRotationScaleJig_Method()
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim ed As Editor = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
Try
Dim selRes As PromptSelectionResult = ed.GetSelection()
If selRes.Status <> PromptStatus.OK Then
Return
End If
Dim prOpt As New PromptPointOptions(vbLf & "Base point:")
Dim pr As PromptPointResult = ed.GetPoint(prOpt)
If pr.Status <> PromptStatus.OK Then
Return
End If
Dim jigger As New MoveRotationScaleJig(pr.Value)
Using tr As Transaction = db.TransactionManager.StartTransaction()
For Each id As ObjectId In selRes.Value.GetObjectIds()
Dim ent As Entity = DirectCast(tr.GetObject(id, Teigha.DatabaseServices.OpenMode.ForWrite), Entity)
jigger.AddEntity(ent)
Next
If jigger.Jig() Then
jigger.TransformEntities()
End If
tr.Commit()
End Using
Catch ex As System.Exception
ed.WriteMessage(ex.ToString())
End Try
Public Shared Sub MoveRotationScaleJig_Method(BasePoint As Point3d, Entities As List(Of ObjectId))
Try
Dim jigger As New MoveRotationScaleJig(BasePoint)
For Each id As ObjectId In Entities
Next
tr.Commit()
Else
tr.Abort()
End If
End Using
End Try
#End Region
End Class
End Namespace
