Looking for Explanation - ThisDocument and Zoomscaled
The VBA forum deals with IntelliCAD 2000 VBA (Visual Basic for Applications) issues.
jwhitla
Post by jwhitla » Fri Dec 21, 2007 6:22 am
Hello,
I'm using version 6.4.23.2 to convert some old Autocad VBA macros and I'm storing all my programs in Common Projects.
Can anyone shed some light on the following:
1) Why I don't have access to ThisDocument and have to use ThisWorkspace.ActiveDocument instead.
2) At the end of the macros, I am attempting to Zoom Extents followed by a Zoom Scale to slightly reduce the view of the drawing.
The ZoomExtents works OK but ZoomScaled is giving a
' Compile Error: = expected'
In Autocad I simply used:
ZoomScale 0.9, acZoomScaledRelative
In Intellicad I have tried
ThisWorkspace.ActiveDocument.ActiveViewport.ZoomScaled (0.9,vicZoomScaledRelative)
but when I type the finishing bracket I get the Compile error message above.
Jim :?
Post by John Finlay » Sat Jan 12, 2008 1:33 pm
jwhitla,
As far as the access to ThisDocument goes: I have always used IntelliCAD.ActiveDocument so I can't help you there.
The zoom works without error when I use:
ThisWorkspace.ActiveDocument.ActiveViewport.ZoomScaled 0.9, vicZoomScaledRelative
The error occurs when brackets are placed around the arguments as VBA needs a pointer to a variable.
jwhitla
Zoom Scaled - Problem Solved
Post by jwhitla » Sun Jan 13, 2008 8:04 am
Thanks John,
Works a treat. I'll remember about the brackets in the future.
