by Alberto
The extrude command creates a solid ACIS entity from a polyline or a region. Is useful to create complex shapes.
My experience in 3D is in Architectural Modelling. The tabsurf is a possible alternative. It has the disadvantage that the shape is extruded, but it is built without "caps", so the top and the bottom of the 3d entity has to be built apart, with the surface commands too.
The advantage to use the surface entities, is file size. So, I prefer, unless is strictly necessary, the surface entities, and plines, lines and circles with added thickness.
ACIS geometry make BIIIIIIG files, and sometimes is is not necessary to use such entities. If you have a ACIS model and export it to .3ds or .dfx format, you'll notice the difference in file size.
Another advantage of surface entities is that they don't have any problem when they're exported to other formats. ACIS sometimes lose curvature or smoothness, and sometimes are not well exported or readed. Well, it has happened to me.
Well, hope this helps, bye
Alberto
