by sidehill
davep
Yes, you are absolutely correct. Each time I fill a polygon I have to reset the pattern. Even if it appears that solid is selected I think you have to either reselect solid or maybe even select a true hatch and then reselect solid to make it stick. I'm not really sure about that, although in one instance it appeared to be set on solid under the pattern tab, but then filled in with the zillion line hatch to appear as solid.
thanks again, it looks like I'll be able to complete this project in ICAD instead of switching to Arcview.
