Registry Key
Has the source code been modified to provide a unique CMS registry key for the free download version of ICAD?
Answering my own question (nothing like talking to oneself) CMS are still using Visio as the registry key. I remember someone on this forum advising CMS to alter this and CMD thought it was a good idea.
CMS have been tardy.
[This message has been edited by JohnF (edited 12-08-2000).]
Hatch command only creates an independent hatch within the drawing entities. Hatches cannot be altered after creation.
BHatch creates a polyline (boundary) around the hatch and the hatch can be associative ie when the boundary is changed the hatch will alter to completely fill it.
You must copy the missing pattern definition to icad.pat(I've never heard of ISO.PAT). You can not switch between hatch definition files with the Hatch command. I would recommend using the bhatch command instead, just uncheck "Associative" and it should work as the hatch command. From the bhatch dialog you can switch between pattern definition files.
