PEDIT - multiple - Join - FUZZ distance?
In AutoCAD when you select multiple polylines to join together you would use command PEDIT -> 'M' for multiple -> select the lines and hit enter -> Join
AutoCAD would then ask you for the FUZZ distance. That is the error allowance between the lines if the lines are not continuous (think gaps between lines allowed for the join)
IntelliCAD does not ask the FUZZ distance. Is this just something I will have to learn to live without?
