IGES Export function
Posted: Tue Mar 16, 2021 1:32 pm
by kam33mitch
I've tested this on a simple box and have confirmed that the scaling is off on the IGES Export function. A simple box 10,10,10 mm exports to a box 10,10,10 meters. If you import the same file back into Intellicad it will show a box 10,10,10 meters so it has to be the scaling in the export. It is indicating mm correctly in the header of the .iges file but the point surface data in the file is off by a factor of 1000x. I can manually edit the .iges file to indicate microns instead of mm but this should not be necessary in a straight export.
is there a variable that can be adjusted on this or does the software need to be updated?
Re: IGES Export function
Posted: Mon May 10, 2021 4:19 pm
by kam33mitch
The new update fixed this issue!
