I have a drawing with 22 sheets of data, when I setup a layout tab and add a view port I get a new file when saving named saved with errors. The file is corrupt and will not recover. Does anyone have any advice for why this is happening, how to prevent it or even how to query the error to resolve the issue.
Is this a known issue in 9.2? Was it resolved in the latest version. No sense in upgrading if the toolset has the same issues.
Also when saving the file it causes my desktop to blink and my quick start menu bar goes away while the blinking occurs. The blinking is the desktop going from the screensaver to black.
Anthony
Re: CMS Intellicad 9.2 PE Plus - Viewport Corruption
#2Hi Antony,
I've not personally come across this issue, as none of my customers uses multi-sheet drawings.
If you are able to attach a copy of the drawing I will be happy to open in version 10 and test for you.
