Re: How can i import .eps format file?
CMS IntelliCAD cannot import encapsulated PostScript ( .eps ) files directly.
As example, it's possible to open .eps using GIMP software and then export it as JPEG or PNG.
EPS has been superseded by PDF.
We recommend the use of PDF or SVG files.
CMS IntelliCAD can export as SVG file and, as example, these can be edited by Inkscape .
Extended file formats image insertion support is available using IMAGEATTACH command, or use the Ribbon Insert tab > Data > Image > Image Attach...
