I have been sent a DGN file to work on by a client.
While the file will open/display in Bentley view, intellicad will not open the file(:
The file is a 3D model of a process plant, created in 2017.
I have tried attaching as an underlay and while the attach worked the end result was flattened.
Intellicad version : 9.0.815.0.PE+.VC15.x64.RF90
PC: I5 4590 3.30GHz
32GB Ram
Geforce GTX 960
256GB SSD ( C drive)
2TB SATA (D drive, data)
Thoughts anyone?
Steve
Re: unable to open dgn file in Intellicad 9.0
#2Hi,
Please check your file is valid again.
I tried to open some dgn files from https://www.q-cad.com/samples/microstat ... d-samples/
The IntelliCAD work well.
- Attachments
- DGN_file.png (182.21 KiB) Viewed 806 times
#3Hi
Here it is in a trial version of microstation.
Steve
Edit:
I have just downloaded the latest intellicad 9.2 as a trial. This also failed to open the file.
Steve
Edit:
