Hi CMS Team,
I've been facing printing issues very often. When a print process is executed, CMS IntelliCAD creates a temporary print file(.ptl or .plt) but doesn't print anything. This doesn't happen the same way, occasionally print happen successfully without saving a print file. I have tested the drawing file in other CAD software on the same PC and didn't face any trouble printing. I've been transferring the license to other computers and still the printing issue persist. All my work are pending and this is really painful. No solutions available on internet.
I tried almost every possible solution that was available. Nothing worked.
I'M SERIOUSLY STUCK AND COUNTING ON YOU. Please let me know if you need any inputs from my side.
Re: Printing Issue (critical and painful)
#2CMS IntelliCAD uses Windows printer drivers. Did you check if you have the printer driver properly updated?
Please report the printer brand name, model, file sample and printing steps to check if we can reproduce the event here as well.
Use the support email address available at our website.
#3Re-installed the printer driver and CMS IntelliCAD. Now it's working fine. Thank you team.
