Entity snaps error
Intellicad 6.6.82.0.P on Windows 7 64 bit.
When drawing a infinite line or ray I can pick any entity snap and the program will not insert the entity at the correct location. The closer I zoom in during the selection the closer the infinite line will be placed to the selected entity but it will still be in error. It will be placed accurately if I key in the location. No problem with drawing a line or circle.
The same problem occurs when using the distance command on the inquiry menu.
So far it seems as if it is tied to the requirement of selecting 2 points. plays a role here.
Any insight would be appreciated.
James Lane
UPDATE: Sorry I didn't try this earlier. I restarted the program and the problem went away. Guess it's a little like the windows mantra:
"For small problems, re-start. For big problems re-install."
